[PROJ] function to get grid transformation data
Even Rouault even.rouault at spatialys.com
Wed Nov 2 12:24:29 PDT 2022
Javier,
cannot you setGridAvailabilityUse(IGNORE_GRID_AVAILABILITY), like in the
following
         auto ctxt =
             CoordinateOperationContext::create(authFactory, nullptr, 0.0);
         ctxt->setGridAvailabilityUse(
             CoordinateOperationContext::GridAvailabilityUse::
                 IGNORE_GRID_AVAILABILITY);
         ctxt->setUsePROJAlternativeGridNames(false);
         auto list = CoordinateOperationFactory::create()->createOperations(
authFactory->createCoordinateReferenceSystem("4275"), // NTF
authFactory->createCoordinateReferenceSystem("4258"), // ETRS89
             ctxt);
and iterate over the returned transformations, and use gridsNeeded() on
them to check which grids are needed, and their availability
Even
Le 02/11/2022 à 18:25, Javier Jimenez Shaw a écrit :
> Hi
> I have a problem determining if a (gravity related height) vertical
> CRS has a corresponding geoid model grid-file in the system or not. In
> other words, if I can expect an actual transformation to that VCRS or
> not. (All this is not using the “PROJ_NETWORK” mechanism to use a
> remote location, but assuming that any file is already in the computer
> I am running).
> I am thinking about developing a PR for C++ that returns some useful
> information about the grid transformations for a given CRS code (doing
> some SQL queries). That will allow the user/developer to know the grid
> files involved for that CRS, and check if they are available on the
> filesystem.
> The API would be something like this:
> struct GridTransformationData {
>     std::string auth_name;
>     std::string code;
>     std::string source_crs_auth_name;
>     std::string source_crs_code;
>     std::string accuracy;
>     std::string param_auth_name;
>     std::string param_code;
>     std::string grid_name;
>     Extent extent;
> std::list<GridTransformationData>
> AuthorityFactory::getGridTransformationData(const std::string &code)
> const;
> To find if the file is in the system, this other function will help to
> search among the tiff files from PROJ-data
> std::string getGridAlternative(const std::string& original_grid_name)
> const;
> Is there already a way to do it?
> Which fields (mainly from grid_transformation table) should I return?
> Probably there are other use cases (maybe not only for vertical CRSs)
> that can take advantage of these functions.
> Thanks.
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20221102/71962229/attachment.htm>
More information about the PROJ mailing list
