[PROJ] Helmet transform between 2 ITRF sets of coordinates
Even Rouault even.rouault at spatialys.com
Tue Nov 15 09:13:57 PST 2022
Alain,
you actually want to do 2 things:
- change the reference frame (from ITRF92 to ITRF2014)
- and change of coordinate epoch in one of the coordinate frames
(presumably in ITRF2014)
You can't do that just by using the 15-parameter ITRF92->ITRF2014
transformation.
So first step, change from ITRF92 to ITRF2014 at epoch 1993.0. You must
use +t_epoch=2010 as it is the canoncial central epoch of the transformation
$ echo -139.57736536   -8.95162075   2.234  1993.0 | cct -d 8
+proj=pipeline +step +proj=cart +ellps=GRS80 +step +proj=helmert
+x=-0.0154 +y=-0.0015 +z=0.0708 +rx=0 +ry=0 +rz=-0.00026 +s=-0.00309
+dx=-0.0001 +dy=0.0005 +dz=0.0033 +drx=0 +dry=0 +drz=-2e-05 +ds=-0.00012
+t_epoch=2010 +convention=position_vector +step +inv +proj=cart +ellps=GRS80
  -139.57736535     -8.95162059    2.24172393     1993.0000
You can also that by using EPSG objects (but using lat, long order)
$ echo -8.95162075  -139.57736536  2.234 1993.0 | cs2cs -d 8 ITRF92 ITRF2014
-8.95162059    -139.57736535 2.24172393 1993.0
and second step, apply the Pacific plate motion Helmert transformation
for ITRF2014:
$ echo   -139.57736535     -8.95162059    2.24172393 2023 | cct -d 8 \
     +proj=pipeline +step +proj=cart +ellps=GRS80 \
     +step +init=ITRF2014:PCFC +t_epoch=1993 \
  -139.57738390     -8.95161168    2.24071029     2023.0000
The ITRF2014:PCFC parameters are at
https://github.com/OSGeo/PROJ/blob/4762020db550ac3b9405970f8830abdb5fefdb48/data/ITRF2014#L51
If inlined:
+drx=-0.000409 +dry=0.001047 +drz=-0.002169 +convention=position_vector
+t_epoch=1993 +step +inv +proj=cart +ellps=GRS80
The difference between the initial and final coordinate in ITRF2014 is
2.272 m.
$ echo  -8.95162075 -139.57736536 -8.95161168 -139.57738390  | geod -I
+ellps=GRS80
-63d48'8.651"    116d11'51.359"    2.272
You could actually concatenate the 2 pipelines by using the +proj=set
+v_4=2023 operator to force the target epoch of the plate motion
transformation
+proj=pipeline \
      +step +proj=helmert +x=-0.0154 +y=-0.0015 +z=0.0708 +rx=0 +ry=0
+rz=-0.00026 +s=-0.00309 \
+drz=-2e-05 +ds=-0.00012 +t_epoch=2010 +convention=position_vector \
      +step +proj=set +v_4=2023 \
      +step +proj=helmert +drx=-0.000409 +dry=0.001047 +drz=-0.002169
+convention=position_vector +t_epoch=1993 \
Even
Le 15/11/2022 à 17:16, Alain Orsoni a écrit :
> Hello,
> I’m trying to convert ITRF92 (epoch 93.0) coordinates to ITRF2014
> epoch 2023.0.
> Having some 8 cms per year movement I expect some 2.4m difference in
> the coordinates.
> I tried some syntaxes but did not understand clearly how (where) to
> indicate the epochs (initial and final) in my tests :
> One test applied was :
> echo -139.57736536  -8.95162075     2.234 2023.0 | cct +proj=pipeline
> +step +proj=cart +ellps=GRS80 +step +proj=helmert +x=-0.0154
> +y=-0.0015 +z=0.0708 +rx=0 +ry=0 +rz=-0.00026 +s=-0.00309 +dx=-0.0001
> +t_epoch=1993 +convention=position_vector +step +inv +proj=cart
> +ellps=GRS80
> Which gave me
> -139.5773658008   -8.9516192265        2.1701     2023.0000
> As result. Difference much lower than expected representing some 20 cm
> variation from one epoch to the other.
> I indicated the final epoch desired in my input and the initial epoch
> in the helmert transform.
> This is probably false, but I did not encounter this kind of
> indication in the documentation.
> Where is the misunderstanding?
> Thank you for any help,
> Alain Orsoni
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20221115/50133f31/attachment.htm>
More information about the PROJ mailing list
