[PROJ] How to uninstall proj?
Laurențiu Nicola lnicola at dend.ro
Wed Oct 5 00:14:03 PDT 2022
PS: sorry, I misread, that install_manifest.txt isn't created by default. There's an entry about this in https://gitlab.kitware.com/cmake/community/-/wikis/FAQ#can-i-do-make-uninstall-with-cmake.
On Wed, Oct 5, 2022, at 10:04, Laurențiu Nicola wrote:
> Hi Tom,
> This isn't specific to proj, but most software doesn't have an uninstall target. You're probably supposed to install it to a different prefix and optionally turn it into a package.
> The general solution is probably to run make install again, take a note of what it's installing, then remove those files. If you used CMake, you might have an install_manifest.txt file with a list of what to remove.
> For completeness, here's what my distro's proj 9.0.1 package contains:
> proj /usr/
> proj /usr/bin/
> proj /usr/bin/cct
> proj /usr/bin/cs2cs
> proj /usr/bin/geod
> proj /usr/bin/gie
> proj /usr/bin/invgeod
> proj /usr/bin/invproj
> proj /usr/bin/proj
> proj /usr/bin/projinfo
> proj /usr/bin/projsync
> proj /usr/include/
> proj /usr/include/geodesic.h
> proj /usr/include/proj.h
> proj /usr/include/proj/
> proj /usr/include/proj/common.hpp
> proj /usr/include/proj/coordinateoperation.hpp
> proj /usr/include/proj/coordinatesystem.hpp
> proj /usr/include/proj/crs.hpp
> proj /usr/include/proj/datum.hpp
> proj /usr/include/proj/io.hpp
> proj /usr/include/proj/metadata.hpp
> proj /usr/include/proj/nn.hpp
> proj /usr/include/proj/util.hpp
> proj /usr/include/proj_constants.h
> proj /usr/include/proj_experimental.h
> proj /usr/include/proj_symbol_rename.h
> proj /usr/lib/
> proj /usr/lib/cmake/
> proj /usr/lib/cmake/proj/
> proj /usr/lib/cmake/proj/proj-config-version.cmake
> proj /usr/lib/cmake/proj/proj-config.cmake
> proj /usr/lib/cmake/proj/proj-targets-release.cmake
> proj /usr/lib/cmake/proj/proj-targets.cmake
> proj /usr/lib/cmake/proj/proj4-targets-release.cmake
> proj /usr/lib/cmake/proj/proj4-targets.cmake
> proj /usr/lib/cmake/proj4/
> proj /usr/lib/cmake/proj4/proj-targets-release.cmake
> proj /usr/lib/cmake/proj4/proj-targets.cmake
> proj /usr/lib/cmake/proj4/proj4-config-version.cmake
> proj /usr/lib/cmake/proj4/proj4-config.cmake
> proj /usr/lib/cmake/proj4/proj4-targets-release.cmake
> proj /usr/lib/cmake/proj4/proj4-targets.cmake
> proj /usr/lib/libproj.so
> proj /usr/lib/libproj.so.25
> proj /usr/lib/libproj.so.25.9.0.1
> proj /usr/lib/pkgconfig/
> proj /usr/lib/pkgconfig/proj.pc
> proj /usr/share/
> proj /usr/share/doc/
> proj /usr/share/doc/proj/
> proj /usr/share/doc/proj/AUTHORS
> proj /usr/share/doc/proj/COPYING
> proj /usr/share/doc/proj/NEWS
> proj /usr/share/licenses/
> proj /usr/share/licenses/proj/
> proj /usr/share/licenses/proj/COPYING
> proj /usr/share/man/
> proj /usr/share/man/man1/
> proj /usr/share/man/man1/cct.1.gz
> proj /usr/share/man/man1/cs2cs.1.gz
> proj /usr/share/man/man1/geod.1.gz
> proj /usr/share/man/man1/gie.1.gz
> proj /usr/share/man/man1/proj.1.gz
> proj /usr/share/man/man1/projinfo.1.gz
> proj /usr/share/man/man1/projsync.1.gz
> proj /usr/share/proj/
> proj /usr/share/proj/CH
> proj /usr/share/proj/GL27
> proj /usr/share/proj/ITRF2000
> proj /usr/share/proj/ITRF2008
> proj /usr/share/proj/ITRF2014
> proj /usr/share/proj/deformation_model.schema.json
> proj /usr/share/proj/nad.lst
> proj /usr/share/proj/nad27
> proj /usr/share/proj/nad83
> proj /usr/share/proj/other.extra
> proj /usr/share/proj/proj.db
> proj /usr/share/proj/proj.ini
> proj /usr/share/proj/projjson.schema.json
> proj /usr/share/proj/triangulation.schema.json
> proj /usr/share/proj/world
> Laurentiu
> On Wed, Oct 5, 2022, at 02:42, Tom O'Reilly wrote:
>> I've built several proj versions from source on ubuntu using cmake/make.
>> But the generated Makefile doesn't seem to have an 'uninstall' target, i.e. 'make uninstall' fails with "no rule to make 'uninstall'"
>> How to uninstall proj when built from source?
>> Thanks
>> Tom
>> Thomas C. O'Reilly
>> Monterey Bay Aquarium Research Institute
>> 7700 Sandholdt Road
>> Moss Landing, California 95039-9644
>> 831-775-1766 (voice)
>> 831-775-1620 (FAX)
>> oreilly at mbari.org (email)
>> http://www.mbari.org (World-wide Web)
>> "The machine does not isolate us from the great mysteries
>>  of nature, but plunges us more deeply into them."
>>    - ANTOINE DE SAINT-EXUPERY
>>      "Wind, Sand, and Stars" (1939)
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20221005/33193fcd/attachment-0001.htm>
More information about the PROJ mailing list
