[PROJ] Learning RTK
Gabriel De Luca pablogabrieldeluca at gmail.com
Mon Oct 17 15:40:21 PDT 2022
Hi, Javier,
This course struck me as a good balance between simplicity and depth. You
will find information about RTK and NTRIP (Real Time Service (RTS-PPP),
under Precise Point Positioning) in the Lesson 8, but the fundamentals are
before. I would recommend start at the beginning and make sure you have a
good idea of the differencing method (where the magic happens):
https://www.e-education.psu.edu/geog862/node/1405
Regards,
Gabriel
El lun, 17 oct 2022 a la(s) 16:51, Javier Jimenez Shaw (j1 at jimenezshaw.com)
escribió:
> Hi PROJ community
> I want to learn more about RTK and NTRIP (PPK as well, but that could be
> another story).
> However everything I find in Internet is either too simple/naïve, or
> protocol specifications (that are too hard and not explaining anything).
> Could you recommend any documentation, tutorial, training, video or
> whatever?
> Thanks,
> Javier
> PS: I studied some physics at university, so I am not afraid of some
> interferences ;)
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20221017/3e2c4473/attachment.htm>
More information about the PROJ mailing list
