[PROJ] Vertical grid transformation / ellipsoidal height to EGM2008 (EPSG 3855)
inti luna inti.luna.rsgis at gmail.com
Thu Sep 15 13:18:50 PDT 2022
Dear PROJ community,
I am using a GNSS (Emlid REACH RS2 )to collect ground control points for
drone mapping and supporting a project of monitoring vegetation after fire.
I have collected data in LAT,LON (CRS EPSG 4326) and ellipsoidal height (m)
and would like to transform it to another CRS. Target horizontal is EPSG:
25831 and target height is based on EGM2008 (EPSG 3855).
I just discovered PROJ and I am having issues with the vertical
transformation.
Using Linux Ubuntu 11 and installed PROJ using anaconda with:
<conda install -c conda-forge proj>
<conda install -c conda-forge proj-data>
I tested with:
<echo -2.69713764 43.37551925 | cs2cs +init=epsg:4326 +to +init=epsg:25830>
which outputs: -2.69713764 43.37551925 which is fine.
However, I don't understand very well how to perform the vertical grid
shift.
I tried:
1. <echo -2.69713764 43.37551925 102.635| cs2cs +init=epsg:4326 +vgridshift
 +to +init=epsg:25830 +grids=egm08_25.gtx>
2.<echo -2.69713764 43.37551925 102.635 | proj +init=epsg:4326
+proj=vgridshift +grids=egm08_25.gtx>
But the first try ignores the height and the second got me an error message:
"can't initialize operations that produce angular output coordinates
program abnormally terminated"
Thank you for your help,
Inti
Inti Luna
+ 34 688756449
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220915/c7050768/attachment.htm>
More information about the PROJ mailing list
