[PROJ] PROJ and Unicode on Windows
Even Rouault even.rouault at spatialys.com
Wed Apr 5 16:30:20 PDT 2023
Le 06/04/2023 à 01:09, Dan Crosby a écrit :
> How does this work on Linux? is char define as wchar there?
No. char is a single byte. wchar_t is generally a 32-bit integer on Unix.
> If Proj is returning UTF8 strings, shouldn’t the functions be using
> wchar, or TCHAR at the least?
I guess this is just a matter of taste/habit. Lots of open source
libraries that return Unicode content just return it as UTF-8 in a char*
(or a std::string in C++. this is typically the case of the
nlohmann/json library we use for JSON parsing).  If you need to access
the string by Unicode character, you can use iconv or
https://en.cppreference.com/w/cpp/locale/codecvt_utf8 in C++ (although
the latter has been deprecated).
> Is there a compatibility reason to use char **?
That's all the reason why UTF-8 was designed for. To be able to deal
with it mostly as if it was an old-school ASCII string.
> *From:*PROJ <proj-bounces at lists.osgeo.org> *On Behalf Of *Peter
> Townsend via PROJ
> *Sent:* Thursday, 6 April 2023 10:38
> *To:* Even Rouault <even.rouault at spatialys.com>
> *Cc:* proj <proj at lists.osgeo.org>
> *Subject:* Re: [PROJ] PROJ and Unicode on Windows
> Well it's not the console I'm worried about, that's coming straight
> from the VS debugger. Knowing that strings are always coming out of
> PROJ in UTF-8 is good.
> Ultimately I'm sending the output to a C# DLL, so I need to
> CoTaskMemAlloc my string. If I do something like this:
> std::wstring s2ws(const char* utf8Bytes)
> const std::string& str(utf8Bytes);
> int size_needed = MultiByteToWideChar(CP_UTF8, 0, &str[0],
> (int)str.size(), NULL, 0);
> std::wstring wstrTo(size_needed, 0);
> MultiByteToWideChar(CP_UTF8, 0, &str[0], (int)str.size(), &wstrTo[0],
> size_needed);
> return wstrTo;
> Then I see the corrected UTF-8 text in the wstring. As mentioned this
> isn't something I'm terribly familiar with, and I'd like to avoid
> writing terrible C code and exploding buffers.
> CoTaskMemAlloc needs the actual number of bytes, and we'll need an
> extra spot for the null terminator.
> const wchar_t* u_convertResult(const char* result) {
> if (!result)
> return nullptr;
> std::wstring wstr = s2ws(result);
> auto wlen = wstr.length() + 1;
> auto len = wlen * sizeof(wchar_t);
> wchar_t* buff = (wchar_t*)CoTaskMemAlloc(len);
> if (buff) {
> wcscpy_s(buff, wlen, wstr.c_str());
> return buff;
> Does this sound reasonable for Windows?
> And as for Linux and maintaining a multi-platform compatibility, I'd
> define an alias function like this instead:
> std::string str(result);
> std::wstring wstr = std::wstring(str.begin(), str.end());
> wchar_t* buff = (wchar_t*)malloc(len);
> if (buff) {
> wcscpy(buff, wstr.c_str());
> return buff;
> Since it's already happily working as UTF-8 on Linux, I should be able
> to pass in the original string to the wstring. CoTaskMemAlloc is just
> malloc. Does this sound okay too?
> Thanks!
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230406/b5614430/attachment.htm>
More information about the PROJ mailing list
