[PROJ] Problems with last EPSG update in Germany
Even Rouault even.rouault at spatialys.com
Sat Apr 29 11:31:12 PDT 2023
Le 29/04/2023 à 19:58, Javier Jimenez Shaw a écrit :
> Thanks Even.
> Yes, I will contact BKG.
> I was thinking on another option: defining a Helmert transformation
> between ETRS89/DREF91/2016 and ETRS89, (probably with 0,0,0 params)
> and some (in)accuracy, to "connect" the new system with the old ones.
> Otherwise the "new" systems and the "old" ones are disconnected and
> only ballpark transformations are possible. Something like
> https://epsg.org/transformation_9703/ETRF2000-PL-to-ETRS89-1.html for
> Poland. (https://epsg.org/search/by-name/?query=ETRF2000-PL sounds
> very similar to
> https://epsg.org/search/by-name?searchedTerms=ETRS89%2FDREF91%2F2016
> but without that "link" to the "old" systems).
> What do you think about this? Would it work?
Yes that also crossed through my mind. I believe it should work (but
beware of the limitations of PROJ inference logic of guessing at most a
single intermediate CRS, but for doing WGS84 -> ETRS89 ->
ETRS89/DREF91/2016, that should work). You might simulate that
beforehand by creating such a Helmert transformation.
http://www.spatialys.com
More information about the PROJ mailing list
