[PROJ] open_license column in proj.db
Javier Jimenez Shaw j1 at jimenezshaw.com
Thu Aug 17 15:33:16 PDT 2023
Hi
Having a look at proj.db, I have seen a column in the table
"grid_alternatives" called "open_license"
What is the purpose of this field? (apart from allowing a meaningless "url")
I guess it is not effectively used in the code.
The three entries with this field to "0" are a bit redundant, right?
"original_grid_name" and "old_proj_grid_name" are the same. Are those
entries needed?
Thanks.
.___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230818/d31f8cf0/attachment.htm>
More information about the PROJ mailing list
