[PROJ] open_license column in proj.db
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Aug 18 02:53:01 PDT 2023
Thanks!
On Fri, 18 Aug 2023 at 10:45, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi Javier,
> > Having a look at proj.db, I have seen a column in the table
> > "grid_alternatives" called "open_license"
> > What is the purpose of this field? (apart from allowing a meaningless
> > "url")
> > I guess it is not effectively used in the code.
> It is reported as a metadata information in
> proj_grid_get_info_from_database(), so users can make an informed
> choice. It is used only for the following 2 grids which are publicly
> available but whose license terms are not considered open data:
> ('naptrans2008.gtx','','naptrans2008.gtx','GTX','geoid_like',0,NULL,'
> https://salsa.debian.org/debian-gis-team/proj-rdnap/raw/upstream/2008/naptrans2008.gtx
> ',1,0,NULL),
> ('rdtrans2008.gsb','','rdtrans2008.gsb','NTv2','hgridshift',0,NULL,'
> https://salsa.debian.org/debian-gis-team/proj-rdnap/raw/upstream/2008/rdtrans2008.gsb
> ',1,0,NULL),
> ('netherlands/rdtrans2008','','rdtrans2008.gsb','NTv2','hgridshift',0,NULL,'
> ',1,0,NULL),
> > The three entries with this field to "0" are a bit redundant, right?
> No I don't think so. There are 2 different grids. And the rdtrans2008
> one has a different name if it is used by EPSG records or ESRI records,
> hence 2 records for it as original_grid_name is the key.
> > "original_grid_name" and "old_proj_grid_name" are the same. Are those
> > entries needed?
> There are tons of records where they are different like:
> INSERT INTO grid_alternatives(original_grid_name,
>                                proj_grid_name,
>                                old_proj_grid_name,
>                                proj_grid_format,
>                                proj_method,
>                                inverse_direction,
>                                package_name,
>                                url, direct_download, open_license,
> directory)
>                        VALUES ('conus.las',
>                                'us_noaa_conus.tif',
>                                'conus',
>                                'GTiff',
>                                'hgridshift',
>                                0,
>                                NULL,
> 'https://cdn.proj.org/us_noaa_conus.tif', 1, 1, NULL);
> old_proj_grid_name corresponds to known grid names by PROJ before PROJ 7
> and the migration to GeoTIFF, so NTv2, CTable2 and GTX files
> original_grid_name corresponds to the """"official"""" name in the
> registry imported by PROJ, so most of the time the one used by EPSG (and
> a few ones from ESRI or IGNF)
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230818/78f36a1a/attachment.htm>
More information about the PROJ mailing list
