[PROJ] PROJ 9.3.0RC1 & PROJ-data 1.15RC1
Kristian Evers kristianevers at gmail.com
Thu Aug 31 22:16:15 PDT 2023
PCS members,
No issues have been reported with PROJ 9.3.0RC2 or PROJ-data 1.15RC1, so I
hereby motion that they are promoted to their final releases.
I’ll start with my +1.
/Kristian
> On 30 Aug 2023, at 20.23, Kristian Evers <kristianevers at gmail.com> wrote:
> All,
> A few minor issues were found in PROJ-9.3.0RC1. They have been fixed and a second release candidate
> is now available. Download it here:
> https://download.osgeo.org/proj/proj-9.3.0RC2.tar.gz <https://download.osgeo.org/proj/proj-9.3.0RC2.tar.gz>
> https://download.osgeo.org/proj/proj-9.3.0RC2.zip <https://download.osgeo.org/proj/proj-9.3.0RC2.zip>
> /Kristian
>> On 27 Aug 2023, at 21.03, Kristian Evers <kristianevers at gmail.com <mailto:kristianevers at gmail.com>> wrote:
>> All,
>> in preparation for a new round of PROJ and PROJ-data release I have uploaded release candidates for both packages.
>> Download the archives here:
>> https://download.osgeo.org/proj/proj-9.3.0RC1.tar.gz <https://download.osgeo.org/proj/proj-9.3.0RC1.tar.gz>
>> https://download.osgeo.org/proj/proj-9.3.0RC1.zip
>> https://download.osgeo.org/proj/proj-data-1.15RC1.tar.gz
>> https://download.osgeo.org/proj/proj-data-1.15RC1.zip
>> The PROJ release includes various updates and bug fixes. See the release notes below.
>> The PROJ-data release adds the following transformations grids:
>> - Argentinian GEOIDE-Ar16geoid model
>> - Polish geoid model PL-geoid2021
>> - Canadian HT2_1997, HT2_1997_CGG2013a, HT2_2002v70 and HT2_2002v70_CGG2013a vertical grids
>> Please test the release candidates and report any issues you may find with them.
>> Either here on the mailing list or on GitHub.
>> /Kristian
>> 9.3.0 Release Notes
>> Updates
>> o Add C++ API to transform coordinate (#3705)
>> o CMake: add PROJ_DB_CACHE_DIR (#3711)
>> o Implement EPSG:1026 Mercator (Spherical) method (#3741)
>> o CMake: remove useless cross-compiling related checks (#3747)
>> o Add mapping of Equidistant Conic to new EPSG:1119 method (#3812)
>> o Implement proposal001 from Planetary DWG from OGC (#3816)
>> o Add option in proj CLI to use a CRS (#3825)
>> o proj_factors(): make it work with projected CRS with non-metre unit and/or
>>   northing/easting axis order (#3826)
>> o PROJ_DEBUG: make ON an alias of 2, and OFF of 1 (#3835)
>> o Database: update to EPSG 10.094 (#3847)
>> Bug fixes
>> o GeographicBoundingBox::intersection(): avoid infinite recursion and stack
>>   overflow on invalid bounding boxes (#3748)
>> o Various fixes related to concatenated operations (#3820)
>> o Projected CRS identification: fix crash when the base CRS is a
>>   non-geographic geodetic CRS (#3830)
>> o Avoid C++ exceptions to be thrown (and caught) when parsing strings
>>   like '+proj=longlat +datum=WGS84 +type=crs' (#3834)
>> o BUG: Handle prefix whitespace when guessing WKT dialiect (#3841)
>> o proj_alter_id(): make it replace an existing ID instead
>>   of appending a new one (#3846)
>> o bonne: fix inverse map projection computations when lat_1 < 0 (#3849)
>> o WKT1 ESRI import/export: fix GCS name for EPSG:8353 S-JTSK_[JTSK03]_Krovak_East_North (#3851)
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230901/cb58c36e/attachment.htm>
More information about the PROJ mailing list
