[PROJ] Make push and pop FIFO?
Thomas Knudsen knudsen.thomas at gmail.com
Thu Dec 14 10:14:51 PST 2023
If your input data does not need time stamps, you may be able to work
around this using +omit_fwd/+omit_inv selectors and a set of
axisswap order=1,2,4,3 steps?
Den tors. 14. dec. 2023 kl. 14.13 skrev Lesparre, Jochem via PROJ <
proj at lists.osgeo.org>:
> Hi list members,
> The PROJ operations +proj=push and +proj=pop use "last in, first out"
> (LIFO) to store and retrieve coordinate values in a stack. It seems that I
> need "first in, first out" (FIFO) or other new functionality in PROJ.
> *Problem*
> The Dutch Caribbean islands use TM-projections based on old datums. We
> have an exact Helmert transformation per island that transforms the
> horizontal coordinates to an ITRS realisation at a specific epoch. For some
> islands we need a geoid (EGM2008 sampled at 45” is the best we have at the
> moment) for the height transformation from local levelling heights to ITRS.
> That works fine for a forward transformation with this PROJ pipeline:
> cct +proj=pipeline
> +step +proj=push +v_3
> +step +proj=tmerc +inv +lat_0=12.180658675 +lon_0=-68.251802281 +k_0=1
> +x_0=23209.5600 +y_0=21423.9900 +ellps=intl
> +step +proj=cart +ellps=intl
> +step +proj=helmert +x=-366.1939 +y=-115.0688 +z=-776.7039 +rx=20.963080
> +ry=16.462749 +rz=-14.276379 +s=-12.80900 +convention=coordinate_frame
> +exact
> +step +proj=cart +inv +ellps=GRS80
> +step +proj=pop +v_3
> +step +proj=vgridshift +grids=egm2008_0_45.tif +inv
> However, I do not get exactly the same results for the inverse
> transformation with -I, since I apply the geoid on the ITRS coordinates,
> but then the physical height is used for the Helmert transformation instead
> of the correct ellipsoidal height. This gives a small error in the
> horizontal coordinates in this case, but can easily reach more than 50
> metres for other CRSs.
> *Solution*
> The most elegant solution seems to me to use FIFO for operations
> +proj=push and +proj=pop, so I can use this pipeline:
> cct +proj=pipeline
> +exact
> *+step +proj=pop +v_3 *
> *+step +proj=pop +v_3 +omit_fwd *
> *Alternative*
> Another possible solution is a new PROJ operation e.g. +proj=flip to make
> the values of a coordinate value and the value stored in the stack switch
> places.
> cct -I +proj=pipeline
> +step +proj=utm +zone=19 +inv +ellps=intl
> +exact
> *+step +proj=flip +v_3 *
> +step +proj=vgridshift +grids=egm96_15.tif +inv
> Regards, Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de
> geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden
> van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and intended
> solely for the use of the individual or entity to whom they are addressed.
> If you are not the intended recipient, you are notified that disclosing,
> copying, distributing or taking any action in reliance on the contents of
> this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products and
> services
> [https://www.kadaster.com/general-terms-and-conditions].
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20231214/905e4074/attachment-0001.htm>
More information about the PROJ mailing list
