[PROJ] World area of use
Even Rouault even.rouault at spatialys.com
Sat Dec 30 11:17:31 PST 2023
Hi Javier,
I don't know the reason for the difference, but if there's one, it would
be interesting to know, and if there's none, converging to World
(without country list, extent 1262) would indeed seem better. Looking at
the few instances that use World by country (extent 2830), there is no
apparent logic. It isn't even related to the type (geographic 2D vs 3D
vs geocentric).
Grep'ping in the change items of the registry (grep epsg_change
PostgreSQL_Data_Script.sql | grep 1262 | grep 2830), shows a global
trend of moving from 2830 to 1262 (with a interesting back & forth for
CRS 8227, IGS14 geocentric, which was changed from 1262 to 2830, and
then later back to 1262)
Even
Le 30/12/2023 à 19:54, Javier Jimenez Shaw via PROJ a écrit :
> Hi
> Playing with crs-explorer, I found that there are a few (and only a
> few) CRSs with an endless "area of use" description:
> https://crs-explorer.proj.org/?latlng=-45.435465,-15.468750&ignoreWorld=false&allowDeprecated=false&authorities=EPSG&activeTypes=GEOGRAPHIC_2D_CRS,GEOGRAPHIC_3D_CRS,GEOCENTRIC_CRS
> <https://crs-explorer.proj.org/?latlng=-45.435465,-15.468750&ignoreWorld=false&allowDeprecated=false&authorities=EPSG&activeTypes=GEOGRAPHIC_2D_CRS,GEOGRAPHIC_3D_CRS,GEOCENTRIC_CRS>
> In EPSG called "World (by country)"
> https://epsg.org/extent_2830/World-by-country.html
> like
> EPSG:4326 <https://epsg.org/crs_4326/WGS-84.html> 	WGS 84
> EPSG:9754 <https://epsg.org/crs_9754/WGS-84-G2139-.html> 	WGS 84 (G2139)
> EPSG:9988 <https://epsg.org/crs_9988/ITRF2020.html> 	ITRF2020
> EPSG:10176 <https://epsg.org/crs_10176/IGS20.html> 	IGS20
> but not some other implementations like
> EPSG:4978 <https://epsg.org/crs_4978/WGS-84.html> 	WGS 84
> EPSG:9753 <https://epsg.org/crs_9753/WGS-84-G2139-.html> 	WGS 84 (G2139)
> EPSG:9055 <https://epsg.org/crs_9055/WGS-84-G1150-.html> 	WGS 84 (G1150)
> (yes, same CRS. The difference is Geographic 2D vs 3D vs geocentric)
> Do you know why this difference?
> Is it something to communicate to EPSG?
> I personally think that that endless list of countries is not needed
> when there is a "World" at front.
> Cheers and happy new year.
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20231230/bfa3603f/attachment.htm>
More information about the PROJ mailing list
