[PROJ] about read the docs
Howard Butler howard at hobu.co
Fri Feb 3 09:51:46 PST 2023
> On Feb 3, 2023, at 11:30 AM, Javier Jimenez Shaw <j1 at jimenezshaw.com> wrote:
> Hi
> due to problems in https://proj.org <https://proj.org/>, I went to read documenation at https://osgeo-proj.readthedocs.io/ ... and the surprise was that it redirected to https://pointcloud.org/ Is that intentional (it looks like) and temporary?
> Another topic: in the applications, for instance https://pointcloud.org/en/9.1/apps/projinfo.html , the parameters with two dashes (like –spatial-test) appears with a single long dash, instead of two dashes. Later below it appears correctly with two: --spatial-test
> I was confused (my memory is not great). I assume that the formatting is done automatically, but it would be clearer with the actual symbol in case anybody copy-pastes it.
Sorry for the mix up. I was testing a RTD deployment using pointcloud.org <http://pointcloud.org/> as the domain this morning. It is an OSGeo-hosted domain that isn't really being used for anything else. This was in preparation for a motion to migrate proj.org <http://proj.org/> to do the same when the PSC makes the motion and votes, etc.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230203/affce8c4/attachment.htm>
More information about the PROJ mailing list
