[PROJ] Latitude of natural origin in Transverse Mercator
Charles Karney charles.karney at gmail.com
Fri Jan 13 07:13:51 PST 2023
These are two interchangeable ways of shifting the northing component of
the projected coordinate.  Mathematically they both do exactly the same
thing and there's nothing the matter with specifying both a latitude of
origin and false northing.  Indeed the Ordnance Survey grid system for
Britain specifies
  central longitude = -2 deg
  latitude of origin = 49 deg
  false northing = - -100 km
This means that a shift is added to the northing component to ensure
that the northing at latitude/longitude = (49 deg, -2 deg) is -100 km.
On 1/13/23 09:28, Javier Jimenez Shaw wrote:
> Hi
> I have a question about Transverse Mercator.
> What is the impact of the parameter "Latitude of natural origin",
> compared with the "False Northing"? (apart from the fact that one is in
> degrees and the other in meters)
> Is there any difference on using a Latitude of natural origin of, let's
> say, 40 degrees, or compute the equivalent False Northing?
> Thanks.
> Javier
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> Entre dos pensamientos racionales
> hay infinitos pensamientos irracionales.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
