[PROJ] CRS aliases
Even Rouault even.rouault at spatialys.com
Fri Jul 21 06:34:36 PDT 2023
> To list all the CRS names I am using  "getCRSInfoList". Great method.
> In some cases I would like to include also all the aliases (more than
> 10000 for projected crs). So you can still find the CRS with the name
> you used all your live. (I'm sure many people do not know that their
> authority renamed a CRS).
> However I am not able to get them. The method
> "IdentifiedObject::aliases()" for a CRS is returning an empty vector,
> and the method "DatabaseContext::getAliases(...)" has a
> "PROJ_INTERNAL" flag that makes it unlinkable.
> Am I doing something wrong with "IdentifiedObject::aliases()"? Is
> there any other way to do it?
If I remember well, this part of the API was something I coded early in
the PROJ 6 work, taking inspiration (and strugling to understand) from
GeoAPI classes. Various classes GenericName, LocalName, NameFactory etc
to deal with basically a string. So the API is there, there's minimum
testing for it in test/unit/test_common.cpp, but it hasn't been really
used for useful stuff.
DatabaseContext::getAliases() is used internally in situations where
identification from the main name fails.
I guess the AuthorityFactory::createXXXX() methods, and more likely the
AuthorityFactory::Private::createPropertiesSearchUsage() low level
method they all use, could be used to query the database and set the
aliases through the ALIAS_KEY property name during construction. There
will obviously be some overhead. No idea if it will be significant or not.
An alternative would be to have a C function relying on
DatabaseContext::getAliases() (or perhaps a helper method at the
IdentifiedObject level) to load the aliases on demand and return them
Even
> Thanks.
> Javier.
> PS: EPSG:32766, projected, has an alias
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230721/fe428a7f/attachment.htm>
More information about the PROJ mailing list
