[PROJ] PROJ 9 & old syntax +init=
Nicolas Bellaiche nicolas.bellaiche at ign.fr
Thu Jun 1 06:54:57 PDT 2023
Hi all,
I am still puzzled by the difference between the old syntax +init= and the new syntax. I just rebuilt the last release 9.2.1 and tested with it to make sure it's not a bug already fixed.
1) Example where the grid shift is not taken into account with the new syntax. (it's correct with +init=)
1.a) NEW SYNTAX: z not correct (grid shift not used)
echo 600000.00000000 300097.53400000 0.00000000 | ./bin/cs2cs IGNF:LAMB1 +to IGNF:UTM31RGF93
452845.19 5583309.40 0.00
1.b) OLD SYNTAX: z correct:
echo 600000.00000000 300097.53400000 0.00000000 | ./bin/cs2cs +init=IGNF:LAMB1 +to +init=IGNF:UTM31RGF93
452845.19 5583309.40 43.64
2) Example where the old syntax gives a wrong result while the new syntax works:
2.a) OLD SYNTAX from cartographic to geocentric coordinates / result is wrong
echo 652760.737 7033791.243 43.642 | PROJ_DEBUG=3 ./bin/cs2cs +init=IGNF:LAMB93 +to +init=IGNF:RGF93
4070355.05 166080.07 4891332.24
2.b) NEW SYNTAX from cartographic to geocentric coordinates / result is correct
echo 652760.737 7033791.243 43.642 | PROJ_DEBUG=3 ./bin/cs2cs IGNF:LAMB93 +to IGNF:RGF93
4070327.25 166078.93 4891298.61
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230601/6bee1a0b/attachment-0001.htm>
More information about the PROJ mailing list
