[PROJ] Determining that two CRSes are "close enough"
Greg Troxel gdt at lexort.com
Thu Jun 15 16:00:43 PDT 2023
Jonathan Kane <jontkane at uw.edu> writes:
> Is there a way in the PROJ API to detect that two CRSes are identical
> enough that the transform between them is the identity transform? Context
> below.
Note that there are ensembles that are not really the same thing but
result in null transforms, e.g. WGS84 and NAD83.   Not sure how you
would want that handled in eq test, how you want transform or not, vs
what proj does now.  A hard problem.
More information about the PROJ mailing list
