[PROJ] Proj9 for ARM/Android
support at mnspoint.com support at mnspoint.com
Thu Jun 29 03:25:10 PDT 2023
We "compile only" PROJ(4) all the time. We don't use unknown binaries at
all (outside what the compiler injects) since one never knows what they
are. I suppose you can (should) also go the same way?
Regards Janne
Sebastian Gellrich kirjoitti 2023-06-29 10:19:
> Hello,
> Are there any plans or experiences to compile Proj9 for ARM systems?
> We would like to integrate Proj9 into our Android app and have so far
> only found implementations based on Proj4 on the internet.
> We want to access the Proj9 library via Android JNI. Mainly we need
> the functions of the cs2cs module.
> Since we have already built Proj9 for x64, we know that other external
> libraries are also created during this process. Do you have any
> experience if these external libraries exist or are compilable for ARM
> systems?
> Thanks in advance
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
