[PROJ] conversion from northing-easing system
Martin Desruisseaux martin.desruisseaux at geomatys.com
Sat Mar 18 04:57:16 PDT 2023
Hello
Le 18/03/2023 à 12:46, Javier Jimenez Shaw a écrit :
> I understand that AXIS tag is not supported in some WKT1 standards
> (well, that is what "I understand" reading WKT2 standard).
Actually AXIS elements are supported in the WKT 1 format as defined by
the OGC 01-009 standard. The problem is that before OGC 01-009, WKT 1
was defined in a much more ambiguous way in a prior OGC specification
named "Simple Features". That prior specification indeed had no AXIS
element (among other ambiguities). OGC 01-009 tried to fix those
ambiguities, but unfortunately it arrived too late; the prior
specification had already been interpreted in different ways by
different software, and we had no reliable way to know which flavor of
WKT 1 a given string was using. WKT 2 resolves that problem by using
different keywords, which makes clear that WKT 2 is used.
     Martin
More information about the PROJ mailing list
