[PROJ] Inconsistent WKT1 output
Even Rouault even.rouault at spatialys.com
Wed Mar 29 11:19:57 PDT 2023
Javier,
yes the conventions are different. PROJ follows (mostly)
https://docs.ogc.org/is/18-010r7/18-010r7.html#37:
Identifier is an optional attribute which references an external
description of the object and which may be applied to a coordinate
reference system, a coordinate operation or a bound CRS. It may also be
utilised for components of these objects although this is recommended
only for the following circumstances:
  * coordinate operation methods and parameters;
  * source and target CRSs when embedded within a coordinate
    transformation or a concatenated coordinate operation;
  * source CRS when embedded within a point motion operation;
  * individual coordinate operations embedded within a concatenated
  * base CRS when embedded within a derived CRS (including projected CRS);
  * source CRS, target CRS and abridged transformation when embedded
    within a bound CRS;
  * individual members of a datum ensemble.
So if the top object has an ID, generally its sub-objects won't have
their IDs emitted, except the above exceptions (I see we don't emit ids
for individual members of a datum ensemble. I remember that those
exceptions have been in flux, so probably this was changed after this
was implemented in PROJ. anyway I would be inclined to to change that
now, as datum ensemble are sufficiently verbose as they are)
See
https://github.com/OSGeo/PROJ/blob/bafe3a91901b4515a8017a6b019e43edb74a0764/src/iso19111/io.cpp#L485
for the logic. It could be tuned to whatever people fancy for their WKT
(there's actually a predefined WKT2_SIMPLIFIED variant where there are
no ids on projection methods and parameters), since the omission of id
is a convention, and not a hard rule
There's always a bit of "tension" about the appropriate verbosity of
WKT: should it be a full dump of the (extract of) the underlying
geodetic database or just a summary with the appropriate level of detail.
Even
Le 29/03/2023 à 18:46, Javier Jimenez Shaw a écrit :
> Hi
> Comparing some WKT1 strings I found something strange. If I ask for
> WKT1_GDAL based on an EPSG code, I get the authorities of the
> spheroid, prime and the datum. However, If I use an WKT2 as the input,
> they are not there.
> Is that expected?
> > projinfo -o wkt1_gdal EPSG:6318
> WKT1:GDAL string:
> GEOGCS["NAD83(2011)",
>     DATUM["NAD83_National_Spatial_Reference_System_2011",
>         SPHEROID["GRS 1980",6378137,298.257222101,
>             AUTHORITY["EPSG","7019"]],
>         AUTHORITY["EPSG","1116"]],
>     PRIMEM["Greenwich",0,
>         AUTHORITY["EPSG","8901"]],
>     UNIT["degree",0.0174532925199433,
>         AUTHORITY["EPSG","9122"]],
>     AUTHORITY["EPSG","6318"]]
> > projinfo -o wkt1_gdal "$(projinfo EPSG:6318 -o wkt2_2019 -q)"
> WKT1:GDAL string:
>         SPHEROID["GRS 1980",6378137,298.257222101]],
>     PRIMEM["Greenwich",0],
> Thank
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230329/41c6a6a6/attachment-0001.htm>
More information about the PROJ mailing list
