[PROJ] Add trivial support for EPSG:1026 operation method?
Even Rouault even.rouault at spatialys.com
Thu May 25 05:56:30 PDT 2023
I've implemented this in https://github.com/OSGeo/PROJ/pull/3741
Even
Le 25/05/2023 à 13:15, Martin Desruisseaux a écrit :
> Hello all
> PROJ does not seem to support the following operation method at this time:
>   * EPSG:1026 — Mercator (Spherical)
>     https://epsg.org/coord-operation-method_1026/Mercator-Spherical.html
> Would it be possible to add it? (I can contribute a patch if I get
> some guidance about which file to edit). The implementation can be
> very trivial:
>  1. If the ellipsoid is not a sphere, raise an error.
>  2. Otherwise treat as synonymous of EPSG:1024 — Popular Visualisation
>     Pseudo Mercator.
> Step 1 could be replaced by the radius of the conformal sphere as
> suggested by EPSG, but the above trivial implementation would be
> sufficient for now for the purpose described below.
> The rational for adding EPSG:1026 support would be for the definition
> of extra-terrestrial CRS. For compatibility with existing software,
> some members of the OGC Planetary working group want to use the
> Pseudo-Mercator projection. However many extra-terrestrial CRS are
> defined on a sphere rather than an ellipsoid. In that particular case,
> Pseudo-Mercator (EPSG:1024) is mathematically equivalent to Spherical
> Mercator (EPSG:1026). The CRS could use former, but I would encourage
> the planetary group to use the latter because it carries a semantic
> difference. The EPSG guidance notes warns the reader about the
> problems of Pseudo-Mercator (non-conformal, etc.). However those
> issues do not apply when the datum uses a sphere. The EPSG guidance
> notes do not mention that fact maybe because Pseudo-Mercator has been
> introduced for use with ellipsoids and is useless on spheres (because
> the existing classical Mercator projection was already doing the exact
> same thing). The use of Pseudo-Mercator on a sphere may give to
> non-experts the false impression that Pseudo-Mercator problems still
> apply, while actually it got the properties of a classical Mercator
> projection, in particular the fact that it become a conformal
> projection. Using "Mercator (Spherical)" operation method instead
> makes that fact clearer. Given that the implementation can be trivial
> — identical to Pseudo-Mercator with only a check for making sure that
> the datum uses a sphere — it seems to me that it would be a reasonable
> addition to what can be expected from software (not only PROJ), and
> that the gain in semantic value is worthy.
>     Martin
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230525/9e6829bc/attachment-0001.htm>
More information about the PROJ mailing list
