[PROJ] Esri "local" projection
Even Rouault even.rouault at spatialys.com
Tue May 30 15:43:20 PDT 2023
Javier,
I suspect you might be able to apply the azimuth by using the infamous
+proj=ob_tran.  The tricky part will be to find on which parameter(s) of
ob_tran (o_lat_p, o_lon_p, lon_0) to map it.
Possibly relevant, there's at least 2 different code implementations
attempting at reproducing the Spilhaus from Esri, which include a
azimuth parameter:
- cf https://github.com/OSGeo/PROJ/issues/1851#issuecomment-943138537
- or
https://github.com/neocarto/bertin/blob/main/src/projections/spilhaus.js
+ https://github.com/d3/d3-geo/blob/main/src/rotation.js
The maths ressemble those of proj=ob_tran
Even
Le 31/05/2023 à 00:24, Javier Jimenez Shaw a écrit :
> Hi
> Some use cases of Esri "local" projection are arriving to my desk.
> This projection works in Esri software, but not in PROJ (obviously
> also not in QGIS)
> One example is this WKT1_ESRI
> PROJCS["Hycroft001",GEOGCS["GCS_North_American_1983",DATUM["D_North_American_1983",SPHEROID["GRS_1980",6378137.0,298.257222101]],PRIMEM["Greenwich",0.0],UNIT["Degree",0.0174532925199433]],PROJECTION["Local"],PARAMETER["False_Easting",13264.924],PARAMETER["False_Northing",46473.418],PARAMETER["Scale_Factor",1.00025],PARAMETER["Azimuth",15.786],PARAMETER["Longitude_Of_Center",-116.7048269],PARAMETER["Latitude_Of_Center",42.88212865],UNIT["Foot_US",0.3048006096012192]]
> Looking at their documentation, it seems to be this one:
> https://desktop.arcgis.com/en/arcmap/latest/map/projections/local.htm
> The biggest difference I see with the Orthographic from PROJ is the
> Azimut parameter. I have the impression that the azimut is just a
> rotation of the axes, but it is not clear to me in the Snyder book
> (page 145. If you do not have it, it is available at
> https://pubs.er.usgs.gov/publication/pp1395 )
> Is there are alternative in PROJ?
> Does it make sense to add this transformation?
> Thanks
> Javier
> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230531/cfdcdaa0/attachment.htm>
More information about the PROJ mailing list
