[PROJ] problem with c++ API coding
Daniel Suson djsuson at gmail.com
Tue May 30 19:06:04 PDT 2023
I am trying to add some code into my program that will take a 180x360
array (or some multiple that maintains a 1:2 ratio) and projects it into
various map projections for displaying on a terminal. My program uses
c++ code, so I'm trying to use the c++ API of PROJ. My first step is to
define the CRS for the input data. I'm trying
crs::GeographicCRS* inputCRS = 0;
inputCRS->create(createMapNameEPSGCode("WGS 84", 4978),
datum::GeodeticReferenceFrame::create(util::createMapNameEPSGCode("World
Geodetic System 1984", 6326),
         Ellipsoid::createSphere(createMapNameEPSGCode("WGS 84", 7030),
         common::Length(6378137))),
cs::CartesianCS::createGeocentric(common::UnitOfMeasure::METRE));
I'm including
#include <proj.h>
#include <proj/crs.hpp>
#include <proj/datum.hpp>
using namespace osgeo::proj;
My problem is that createMapNameEPSGCode is included in
operations/oputils.hpp, which is not copied into the include directory
when PROJ is built. Is this a problem with how PROJ was installed, or am
I missing something regarding how to get access to this?
More information about the PROJ mailing list
