[PROJ] accuracy or conversion time limit
Greg Troxel gdt at lexort.com
Mon Nov 20 04:30:59 PST 2023
Hunter1972 via PROJ <proj at lists.osgeo.org> writes:
> Is it possible to specify accuracy of projection conversion or even
> better time limit for the operation?
Rather than asking an open-ended question what would leave people
guessing and using their time to give answers that are probably not on
point, could you explain
  what you are actually trying to do?
  what kinds of processing times are happening for your current use?
  what you have tried to do, based on having read the documentation?
More information about the PROJ mailing list
