[PROJ] Horner polynomial evaluation
molnar molnar at sas.elte.hu
Tue Nov 21 11:53:15 PST 2023
Dear list members, Dear Jochem,
thanks for the detailed description, it would have been very useful for
me two years ago, when I prepared a paper, where I used Horner
Polynomials for transforming ellipsoidal coordinates to spherical
coordinates.
The oblique Mercator projection used in Hungary (EOV, epsg:23700), is
defined in GIS environment as Hotine (or Swiss) Oblique Mercator.  As it
is a two-step projection, using the pipeline operator, an alternative
method can be defined,that coincides the original definition of the
projection: first ellipsoidal coordinates are transformed to spherical
coordinates on the Gauss sphere (aposphere) and in the second step the
spherical form of the oblique Mercator projection equations are applied
on these spherical coordinates to get the projected coordinates.
The pipeline operator enables us to apply this two step method, and we
wanted to use the Horner method, for the first step, to transform the
ellipsoidal coordinates to spherical coordinates. (The coefficients were
published in the standardization document, published in 1972, in the
calculator era).
The manual of Horner Polynomial Evaluation on proj.org states, that both
input and output coordinates can be either geodetic, either projected,
but we could not apply the method on geodetic coordinates in a cct
pipeline.
As a roundabout process, in the pipeline,
1:
the input geodetic coordinates were converted to fake 'projected'
coordinates, using the
+step +proj=eqc +a=57.295779513082323
that literally does not change(!) the figures, but proj regards the
output as projected coordinates. The equidistant cylindrical projection
with +a=57.29... Earth radius ('a' is actually 1 radian in degrees)
converts 47 degree North latitude and 19 degree East longitude to 47
meter Northings, and 19 meter Eastings...
2:
We used Horner Polynomial Evolution to modify the coordinates. Proj
believes that it transforms projected coordinates to projected
coordinates.
3:
We used the inverse projection, to get ellipsoidal (actually spherical)
coordinates:
+step +proj=eqc +a=57.295779513082323 +inv
and we finally used the spherical form of the oblique Mercator
projection.
The details are in the paper:
https://www.fig.net/resources/proceedings/fig_proceedings/fig2022/papers/ts01c/TS01C_molnar_toth_11649.pdf
Regards, Gabor
On 2023-11-21 16:23, Lesparre, Jochem via PROJ wrote:
> Dear list members,
> The implementation of +proj=horner is nice. I used it to reproduce a
> 99 year old polynomial transformation of an even older Dutch CRS
> published in 1827.  However, I encountered some problems with the
> documentation on
> https://proj.org/en/9.3/operations/transformations/horner.html. The
> order of the coefficients in the formulas and in the description of
> the PROJ parameters (+fwd_u and +fwd_u) seem mutually inconsistent.
> PROBLEM 1: The matrix formula (after formula 3) seems inconsistent
> with formula (1) and the actual implementation.
> \begin{bmatrix}
>      u_{0,1} + u_{0,2} U + ... & u_{1,0} + u_{1,1} U + u_{2,0} V + ...
>      v_{1,0} + v_{1,1} V + v_{2,0} U + ... & v_{0,1} + v_{0,2} V \\
> \end{bmatrix}
> should be changed to:
> \begin{bmatrix}
>      u_{1,0} + u_{2,0} U + ... & u_{0,1} + u_{1,1} U + u_{0,2} V + ...
>     v_{0,1} + v_{1,1} V + v_{0,2} U + ... & v_{1,0} + v_{2,0} V \\
> \end{bmatrix}
> PROBLEM 2: The description of the parameters seems inconsistent with
> +fwd_u=<u_11,u_12,...,u_ij,..,u_mn>
> and
> +fwd_v=<v_11,v_12,...,v_ij,..,v_mn>
> +fwd_u=<u_00,u_10,...,u_ij,..,u_nn>
> and
> +fwd_v=<v_00,v_01,...,v_ij,..,v_nn>
> As a result it was difficult to determine the correct order of the
> coefficients for +fwd_u and +fwd_v parameters. I think it would be
> clarifying to add a table for the order of the coefficients in the
> documentation (example for +deg=3):
> Order of coefficients of +fwd_u:
>     | x^0 | x^1 | x^2 | x^3
> y^0 | 1   | 2   | 3   | 4
> y^1 | 5   | 6   | 7   | -
> y^2 | 8   | 9   | -   | -
> y^3 | 10  | -   | -   | -
> Order of coefficients of +fwd_v:
> y^0 | 1   | 5   | 8   | 10
> y^1 | 2   | 6   | 9   | -
> y^2 | 3   | 7   | -   | -
> y^3 | 4   | -   | -   | -
> SUGGESTION FOR A DIFFERENT IMPLEMENTATION: Actually, I would have
> preferred a different order of the coefficients in the implementation,
> in a way that the order would be the same for +fwd_u and +fwd_v, and
> it would keep the first coefficients the same when increasing the
> degree (+deg) of the polynomial:
> Order of coefficients of +fwd_u and +fwd_v:
> y^0 | 1   | 2   | 4   | 7
> y^1 | 3   | 5   | 8   | -
> y^2 | 6   | 9   | -   | -
> Regards, Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor
> de geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of
> verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene
> leveringsvoorwaarden van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and
> intended solely for the use of the individual or entity to whom they
> are addressed.
> If you are not the intended recipient, you are notified that
> disclosing, copying, distributing or taking any action in reliance on
> the contents of this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products
> and services
> [https://www.kadaster.com/general-terms-and-conditions].
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
