[PROJ] accuracy or project conversion
Even Rouault even.rouault at spatialys.com
Mon Nov 27 14:29:24 PST 2023
look at the result of
https://proj.org/en/9.3/search.html?q=accuracy&check_keywords=yes&area=default
However that will not help you for your need. The accuracy settings in
the above functions is to have a "guaranteed" accuracy, but you the most
precise coordinate operation in the candidates that match that accuracy.
And this is mostly for transformations (datum shifts, etc.)
For your case where it is for a map projection, and for the very
particular case of Transverse Mercator, you can use the +approx switch.
Cf https://proj.org/en/9.3/operations/projections/utm.html . Can also be
achieved with +algo=evenden_snyder mentioned just below.
Even
Le 27/11/2023 à 23:23, Hunter1972 via PROJ a écrit :
> Hello,
> Is it possible to specify accuracy of project conversion between different CRS?
> In particular I am interested in UTM <-> WGS84 conversion)routines to be much faster with lower accuracy (around 1m is enough).
> Ravil
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20231127/59dd1120/attachment.htm>
More information about the PROJ mailing list
