[PROJ] Installing the projection package
Rhea rhea.moubarak at gmail.com
Wed Oct 18 07:27:00 PDT 2023
hello again,
is there a way to do the download for centOS ?
i cant seem to find it in the documentation.
Thank you for your help.
Regards,
Rhea
> On 15 Sep 2023, at 3:45 PM, Jürgen E. Fischer <jef at norbit.de> wrote:
> Hi Rhea,
> On Fri, 15. Sep 2023 at 15:34:16 +0200, Rhea wrote:
>> We noticed that we are missing the file: https://github.com/OSGeo/proj-datumgrid/blob/master/ntf_r93.gsb in the proj folder.
>> For installing the file if there is a projection package ? Before on proj 4, we had a projection package with this file: dnf install *proj* does this still exist for proj 8?
> proj-datumgrid it archived: "NOTE: This repository is only to be used with PROJ < 7. For PROJ 7 or later, use the PROJ-data repository."
> ie. https://github.com/OSGeo/PROJ-data
> See also https://proj.org/en/9.3/download.html
> Jürgen
> Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
> Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
> Software Engineer           D-26506 Norden            https://www.norbit.de
> QGIS release manager (PSC)  Germany                 IRC: jef on Libera|OFTC
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
More information about the PROJ mailing list
