[PROJ] Which forms of TIFF compression are used for the CDN grids?
Even Rouault even.rouault at spatialys.com
Thu Apr 4 10:47:58 PDT 2024
Hi Sean,
This is actually documented at
https://proj.org/en/9.4/specifications/geodetictiffgrids.html: "Files
hosted on the CDN will use Compression
<https://www.awaresystems.be/imaging/tiff/tifftags/compression.html> =
DEFLATE or LZW" . I've also just verified that the reality matches the
documented statement. We only use DEFLATE.
Even
Le 04/04/2024 à 19:43, Sean Gillies via PROJ a écrit :
> Hi all,
> I'm building some fiona and rasterio binary packages. They include
> PROJ, and TIFF to get the PROJ grids. On Windows, I'm relying on vcpkg
> for everything, and currently the liblzma port is broken. If I patch
> vcpkg to disable liblzma, will my builds be able to access data in the
> CDN grids?
> Thanks,
> Sean Gillies
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240404/e9e2c3ee/attachment.htm>
More information about the PROJ mailing list
