[PROJ] geoid model from a geographic 2D
Even Rouault even.rouault at spatialys.com
Thu Apr 4 10:52:18 PDT 2024
Le 04/04/2024 à 14:34, Javier Jimenez Shaw a écrit :
> I have already asked the SLA in Singapore. Let's see what happens.
> If I identified it as "PROJ:SVY21_3D", and later they update EPSG
> with, let's say, "EPSG:100"
> is there a way to say to proj.db that they ("PROJ:SVY21_3D" and
> "EPSG:100") are the same thing, and that my added one "PROJ:SVY21_3D"
> can be replaced by the new "EPSG:100"?
> I don't know if the table "alias_name" is for that purpose, or only to
> updated names.
As far as I can remember, we don't have a way to express in the database
that several entries are aliases of each other. The Topic 2 abstract
model or WKT have provision to have several IDs per object, but we don't
make use of that.  The alias_name table has a different purposes:
handling the fact that object names may change, and to be able to match
a deprecated/old name to the object that used to use it. Typically when
processing WKT that don't have IDs.
http://www.spatialys.com
More information about the PROJ mailing list
