[PROJ] Geo TIFF non-ASCII encodings
Mircea Neacsu mircea at neacsu.net
Fri Apr 5 04:24:57 PDT 2024
> Anyway this would be more a topic for an issue at
> https://github.com/opengeospatial/geotiff/issues . I've added a note
> to the existing
> https://github.com/opengeospatial/geotiff/issues/56#issuecomment-2039505940
Understood, but before jumping there with my opinionated ideas, let me
point out that the root of the problem is the TIFF6.0 standard that
continues to define field type 2 as ASCII. Their exact wording is:
"8-bit byte that contains a 7-bit ASCII code; the last byte must be NUL
(binary zero)" (page 15)
IMO everything would work just fine if this would be replaced with
"8-bit byte that contains UTF8 code units; the last byte must be NUL
(binary zero)". Given that UTF-8 is an extension of ASCII, backwards
compatibility wouldn't be so bad.
Mircea Neacsu
On 4/5/2024 6:59 AM, Even Rouault wrote:
> Hi,
> OGC GeoTIFF mostly formalizes the historical GeoTIFF 1.0 specification
> from 1995, and UTF-8 at that time was still in its youth years. Not to
> be mentioned that GeoTIFF was initially developed by NASA' JPL, so I
> assume ASCII was good enough at that time for their purpose. As far as
> I can see all EPSG CRS names as currently only use ASCII. It is true
> though that WKT CRS potentially allows for more than ASCII for CRS
> name, but only in the Latin1 character set.
> to the existing
> Even
> Le 05/04/2024 à 12:44, Mircea Neacsu via PROJ a écrit :
>> Hello,
>> I had to read a bit deeper the Geo TIFF 1.1 standard and I was quite
>> surprised to see that in doesn't allow any character representation
>> outside the 7-bit ASCII text. Am I missing something?
>> In particular CitationGeoKeys that are mandatory in certain cases do
>> not allow for anything other than ASCII text. Seems a bit strange for
>> an international standard.
>> Mircea Neacsu
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> http://www.spatialys.com
> My software is free, but my time generally not.
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240405/8674f996/attachment.htm>
More information about the PROJ mailing list
