[PROJ] Make push and pop FIFO?
Even Rouault even.rouault at spatialys.com
Fri Feb 2 15:45:03 PST 2024
Jochem,
I actually just needed that functionnality, so I've just implemented it,
along a variation of what I proposed previously, adding a +bank=<name>
parameter to push/pop
Cf https://github.com/OSGeo/PROJ/pull/4033
Even
Le 29/01/2024 à 17:15, Lesparre, Jochem via PROJ a écrit :
>> Adding a variable name could made be optional? In that case +push +v_3 and +pop +v_3 would still work the old way, but one could also use +push +v_3 +name=ellipsoidalheight and +pop +v_3 +name=ellipsoidalheight.
> Could my suggestion above, provide a workable compromise for the solution of my problem? What is needed to find consensus on this topic, or should I create a feature request without specifying a specific solution?
> Regards, Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden].
> Disclaimer:
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
> If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products and services
> [https://www.kadaster.com/general-terms-and-conditions].
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
More information about the PROJ mailing list
