[PROJ] Help needed for a cs2cs pipeline with shift grids
Even Rouault even.rouault at spatialys.com
Sun Feb 18 06:16:44 PST 2024
Nicolas,
I believe the Helmert transformation is used when using IGNF codes,
because the IGNF database has only recorded the use of the ntf_r93 grid
for NTF to RGF93, but not for NTF to ETRS89 (by the way, just
reiterating that IGN is more than welcome to take over on maintenance &
updates of the IGNF part of the PROJ database). And when transforming
between 2 IGNF codes, PROJ by default will only consider transformations
in the IGNF domain. But if you use EPSG codes, then ntf_r93 is available
to transforme between NTF and ETRS89.
To get a vertical transformation, you also need to use 3D CRS.
For example
projinfo -s "NTF geographiques Paris (gr) + NGF-IGN69 height" -t
IGNF:ETRS89LCC --3d --spatial-test intersects
reports the following pipeline:
unknown id, axis order change (2D) + NTF (Paris) to NTF (1) + NTF to
RGF93 v1 (1) + Inverse of RGF93 v1 to NGF-IGN69 height (1) + RGF93 v1 to
ETRS89 (1) + axis order change (geographic3D horizontal) + ETRS89
LAMBERT CONFORMAL CONIC, 1.6 m, France - mainland onshore., at least one
grid missing
PROJ string:
+proj=pipeline
   +step +proj=unitconvert +xy_in=grad +xy_out=rad
   +step +inv +proj=longlat +ellps=clrk80ign +pm=paris
   +step +proj=push +v_3
   +step +proj=cart +ellps=clrk80ign
   +step +proj=xyzgridshift +grids=fr_ign_gr3df97a.tif +grid_ref=output_crs
         +ellps=GRS80
   +step +inv +proj=cart +ellps=GRS80
   +step +proj=pop +v_3
   +step +proj=vgridshift +grids=fr_ign_RAF18.tif +multiplier=1
   +step +proj=lcc +lat_0=52 +lon_0=10 +lat_1=35 +lat_2=65 +x_0=4000000
         +y_0=2800000 +ellps=GRS80
Here, as there's a mix of objects from different authorities (IGNF and
EPSG), then EPSG transformations are considered, hence you get the
gr3df97a grid.
$ echo 0  56.000000 0  | PROJ_NETWORK=ON bin/cs2cs -d 3  "NTF
geographiques Paris (gr) + NGF-IGN69 height" IGNF:ETRS89LCC --3d
3474789.997    2655359.291 43.644
which is the application of the above pipeline:
$ echo 0  56.000000 0  | PROJ_NETWORK=ON bin/cct -d 3 +proj=pipeline
+step +proj=unitconvert +xy_in=grad +xy_out=rad +step +inv +proj=longlat
+ellps=clrk80ign +pm=paris +step +proj=push +v_3 +step +proj=cart
+ellps=clrk80ign +step +proj=xyzgridshift +grids=fr_ign_gr3df97a.tif
+grid_ref=output_crs +ellps=GRS80 +step +inv +proj=cart +ellps=GRS80
+step +proj=pop +v_3 +step +proj=vgridshift +grids=fr_ign_RAF18.tif
+multiplier=1 +step +proj=lcc +lat_0=52 +lon_0=10 +lat_1=35 +lat_2=65
+x_0=4000000 +y_0=2800000 +ellps=GRS80
If you want to get exactly the below pipeline, you'll have to tweak
proj.db to create a compound CRS for "NTF geographiques Paris (gr) +
NGF-IGN69 height", and then create a custom record in
other_transformation for the transformation between this compound CRS
and (a 3D projected CRS derived from) IGNF:ETRS89LCC. Cf
data/sql/other_transformation_custom.sql for potential inspiration
Even
Le 15/02/2024 à 19:46, Nicolas Bellaiche via PROJ a écrit :
> Hi there,
> I try to make a conversion using shiftgrids from IGNF: NTFP to
> IGNF:ETRS89LCC. By default, it seems that it uses the helmert
> approximation between the 2 crs and i cannot figure out how to use the
> grid fr_ign_ntf_r93.
> So far i've found how to create a pipeline that works with cct, but
> i'd like to have a code that represents the crs and be able to go to
> different destination crs with the cs2cs application. Any idea?
> (helmert approx + no geoid with the standard codes)
> echo 0 560 | ./cs2cs+ from IGNF:NTFP+to IGNF:ETRS89LCC
> result  : 3474788.212655358.23 0.00
> (correct pipeline)
> echo 0 56.000000 0  | PROJ_DEBUG=3  ./cct    +proj=pipeline +step
> +ellps=clrk80ign +pm=paris  +step +proj=hgridshift
> +grids=fr_ign_ntf_r93.tif +step +inv +proj=vgridshift
> +grids=RAF09.gtx  +step +proj=lcc +lat_0=52 +lon_0=10 +lat_1=35
> +lat_2=65 +x_0=4000000 +y_0=2800000 +ellps=GRS80
> result : 3474789.9972 2655359.2908 43.6421 inf
> reference from THE official IGN/SGN dataset:
> 3474789.9972655359.29143.642
> Thanks a lot for your help,
> Nicolas Bellaiche
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240218/5ade0a08/attachment-0001.htm>
More information about the PROJ mailing list
