[PROJ] PROJ 9.4.0RC1 & PROJ-data 1.17RC1
Even Rouault even.rouault at spatialys.com
Wed Feb 28 09:17:32 PST 2024
Le 28/02/2024 à 17:46, Kristian Evers via PROJ a écrit :
> You guys are clearly using different tools than I am… I can’t for the life of me get those two files to show up when unpacking the RC2 tarball. I’m sure you’re right, you are both smarter at this than I am but I don’t think that it makes much sense for me make RC3 without being able to confirm that it actually works.
Kristian, are you doing that on Windows? Perhaps your archive manager
filters out files starting with dot. Perhaps you should just wipe out
your existing git clone, and recreate one from scratch. Hopefully that
will remove hidden files. Or perhaps tweak your file manager to display
hidden files to be able to delete them manually.
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240228/5b785cb5/attachment-0001.htm>
More information about the PROJ mailing list
