[PROJ] PROJ 9.4.0RC1 & PROJ-data 1.17RC1
Even Rouault even.rouault at spatialys.com
Wed Feb 28 09:57:32 PST 2024
well, there were still there. To share the burden, I've just manually
created a RC4 from a repackaged RC3 on the download server by doing:
mkdir tmp
cd tmp
tar xvzf ../proj-data-1.17RC3.tar.gz
rm ._*
tar cvzf ../proj-data-1.17RC4.tar.gz *
zip ../proj-data-1.17RC4.zip *
So hopefully the below should be the final version... (fingers crossed)
https://download.osgeo.org/proj/proj-data-1.17RC4.tar.gz
https://download.osgeo.org/proj/proj-data-1.17RC4.zip
Even
Le 28/02/2024 à 18:28, Kristian Evers a écrit :
> I’m on a Mac and they don’t always behave as you would expect coming
> from a Linux system. For instance, Bas’ tar command doesn’t fly with
> my particular brand of tar:
> $ tar tavf proj-data-1.17RC2.tar.gz | grep '\._'
> tar: Option -a is not permitted in mode -t
> Unpacking the file surprisingly doesn’t reveal anything either. You’d
> think this sort of thing was easy to figure out but here we are. I am
> not the release manager you deserve but the one you got. Sorry.
> I’ve run a git clean and applied Bas’ patch locally:
> https://download.osgeo.org/proj/proj-data-1.17RC3.tar.gz
> https://download.osgeo.org/proj/proj-data-1.17RC3.zip
> If they don’t work I officially resign as release manager.
> /Kristian
>> On 28 Feb 2024, at 18.17, Even Rouault via PROJ
>> <proj at lists.osgeo.org> wrote:
>> Le 28/02/2024 à 17:46, Kristian Evers via PROJ a écrit :
>>> You guys are clearly using different tools than I am… I can’t for the life of me get those two files to show up when unpacking the RC2 tarball. I’m sure you’re right, you are both smarter at this than I am but I don’t think that it makes much sense for me make RC3 without being able to confirm that it actually works.
>> Kristian, are you doing that on Windows? Perhaps your archive manager
>> filters out files starting with dot. Perhaps you should just wipe out
>> your existing git clone, and recreate one from scratch. Hopefully
>> that will remove hidden files. Or perhaps tweak your file manager to
>> display hidden files to be able to delete them manually.
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240228/6f363625/attachment.htm>
More information about the PROJ mailing list
