[PROJ] PROJ 9.4.0RC1 & PROJ-data 1.17RC1
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Feb 28 10:13:35 PST 2024
So don't worry Kristian, it is not you, it is Mac ;)
For the next time we should use a different prefix, now that we know that
Mac is doing something special.
On Wed, 28 Feb 2024 at 19:04, Sebastiaan Couwenberg via PROJ <
proj at lists.osgeo.org> wrote:
> On 2/28/24 6:28 PM, Kristian Evers via PROJ wrote:
> > I’m on a Mac and they don’t always behave as you would expect coming
> from a Linux system. For instance, Bas’ tar command doesn’t fly with my
> particular brand of tar:
> > $ tar tavf proj-data-1.17RC2.tar.gz | grep '\._'
> > tar: Option -a is not permitted in mode -t
> -a is likely a GNU tar specific option. I'm remember cursing grep on
> Solaris not supporting -A/-B/-C back in the day.
> `tar tzvf proj-data-1.17RC2.tar.gz` does work on Mac, but it ignores the
> ._ files, they are also not present after unpacking the archive.
> > Unpacking the file surprisingly doesn’t reveal anything either. You’d
> think this sort of thing was easy to figure out but here we are. I am not
> the release manager you deserve but the one you got. Sorry.
> Apparently the ._ files are an Mac thing for extended attributes:
> https://unix.stackexchange.com/questions/282055/a-lot-of-files-inside-a-tar
> Kind Regards,
> Bas
>   GPG Key ID: 4096R/6750F10AE88D4AF1
> Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240228/c3db67b9/attachment.htm>
More information about the PROJ mailing list
