[PROJ] Bump CMake to 3.14+
Even Rouault even.rouault at spatialys.com
Mon Jan 8 09:43:36 PST 2024
I'm also supporting of bumping to CMake 3.16+. You'll have at least to
retire the .github/workflows/linux_gcc_5_4.yml workflow, which has no
value any longer
Even
Le 05/01/2024 à 22:18, Erixen Cruz via PROJ a écrit :
> Hello,
> I would like feedback about possibly bumping the minimum CMake version
> for PROJ to 3.14+. This idea comes from
> https://github.com/OSGeo/PROJ/pull/3987  where I want to use CMake's
> FindSQLite3 instead of PROJ's
> https://cmake.org/cmake/help/latest/module/FindSQLite3.html .
> 3.16 is available in Travis CI with the Focal (Ubuntu 20.04 LTS)
> distribution
> https://docs.travis-ci.com/user/reference/focal/#compilers-and-build-toolchain .
> Its possible to install a 3.14+ version on Bionic (18 LTS), which is
> what PROJ uses now.
> 3.14 was release nearly five years ago
> https://www.kitware.com/cmake-3-14-0-available-for-download/ so two
> year old requirement from RFC 3 holds.
> What suggestions or problems do you have with this version bump?
> Sincerely,
> Erixen
> <https://www.kitware.com/cmake-3-14-0-available-for-download/>
> CMake 3.14.0 available for download
> I am happy to announce that CMake 3.14.0 is now available for download
> at:https://cmake.org/download/ The first two 3.14.0 release candidates
> included the FindOcatave module. This has been removed in rc3, and rc4
> pending further development. Documentation is available
> at:https://cmake.org/cmake/help/v3.14 Release notes appear below and
> are also published
> athttps://cmake.org/cmake/help/v3.14/release/3.14.html Some of the
> more significant changes in […]
> www.kitware.com
> <https://github.com/OSGeo/PROJ/pull/3987>
> Link to explicit SQLite3 target by ErixenCruz · Pull Request #3987 ·
> OSGeo/PROJ <https://github.com/OSGeo/PROJ/pull/3987>
> Added clear title that can be used to generate release notes This
> change originates from Conan conan-io/conan-center-index#21512
> (comment). I create an explicit SQLite::SQLite3 target library and ...
> github.com
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240108/3ba8b3e2/attachment.htm>
More information about the PROJ mailing list
