[PROJ] CSRS Epoch 2017.50 (NAD83)
Brian Shaw brian.shaw at noaa.gov
Fri Jan 26 11:12:53 PST 2024
All
Yes we are aware of this California Datum and it was developed by the
California Spatial Reference Center
<http://sopac-csrc.ucsd.edu/index.php/csrc/>
(http://sopac-csrc.ucsd.edu/index.php/csrc/) at the request of
CALTRANS.  As suggested with California being on two tectonic plates
with earthquakes that cause large displacements they needed to have a
more updated datum than the time frame that NGS develops them.  I cannot
specifically recall the earthquake that initiated this datum but I think
it may have been one near Napa.  In my presentations I highlight the
challenges California has due to earthquakes (China Lake in 2019 cause
6-10 feet of horizontal shift) and from subsidence (San Joaquin Valley
USGS study showed up to 2 feet of subsidence in 16 months).  If
interested here is a presentation I provided that has some of this
information
(https://geodesy.noaa.gov/web/science_edu/presentations_library/files/shaw_nsrs_mod_nsgic_20230928.pptx)
Since Esri is based in California I suspect that is why they implemented
it but this is not an NGS developed datum so I believe CSRC or CALTRANS
would have to submit it to EPSG.
I hope this helps
Brian
On 1/26/2024 11:02 AM, Even Rouault via PROJ wrote:
> Hi,
> interesting... It is known by ESRI as
> https://spatialreference.org/ref/esri/104024/ but AFAICS, there isn't
> any transformation registered in their database between this datum and
> other North American datums.
> There's a slide deck talking about it, where HTDP is mentionned
> (https://www.ngs.noaa.gov/TOOLS/Htdp/Htdp.html) :
> https://geodesy.noaa.gov/geospatial-summit/year-2019/files/martin-coordinates-moving.pptx
> , but I've the feeling the message might be that Californians found
> HTDP to not be faithful enough for their purpose. I dunno.. I guess
> our friends from NGS could confirm or infirm.
> I guess the reason for a separate datum is that part of California is
> anchored on a separate tectonic plate than the rest of N.A (or even
> the parts on the N.A. plate are subject to high deformation).
> Presumably this will be obsoleted by the NATRF2022 when it comes into
> life, and interestingly I found in
> https://casetext.com/statute/california-codes/california-public-resources-code/division-8-surveying-and-mapping/chapter-3-geodetic-datums-and-the-california-spatial-reference-network/section-8852-nad83-natrf2022-or-patrf2022
> that states "The official geodetic datum to which horizontal positions
> and ellipsoid heights are referenced within the State of California
> shall be NAD83, NATRF2022, or PATRF2022". Oh joy!
> Even
> Le 26/01/2024 à 18:24, Javier Jimenez Shaw via PROJ a écrit :
>> Hi
>> I discovered today that there is a datum in California called "CSRS
>> Epoch 2017.50 (NAD83)"
>> http://geoweb99.ucsd.edu/index.php/epoch2017/
>> "CSRS Epoch 2017.50(NAD83) replaces the previous “CSRS Epoch 2011.00
>> ITRF2005 NAD83(NSRS2007)” datum that included coordinates for 830
>> CSRN stations."
>> I have not seen it before, so I guess there is no CRS using it in
>> EPSG. (I do not find that datum in EPSG)
>> How can it be used with PROJ?
>> (Is it normal that some states use their own datum in the US? It is
>> not enough with hundred of State Planes ;)
>> Cheers,
>> Javier.
>> PS. Be careful with the acronyms:
>> CRS: Coordinate Reference System
>> CSRC: California Spatial Reference Center
>> CSRS: California Spatial Reference System
>> NAD83(CSRS): Canadian Spatial Reference System
>> So "NAD83(CSRS)" and "CSRS (NAD83)" are not the same.
>> .___ ._ ..._ .. . ._.  .___ .. __ . _. . __..  ... .... ._ .__
>> PROJ mailing list
>> PROJ at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/proj
> http://www.spatialys.com
> My software is free, but my time generally not.
> PROJ mailing list
Brian Shaw
Rocky Mountain Regional Advisor (CO, MT, WY)
NOAA's National Geodetic Survey (NGS)
Cell Phone # 240-988-6363
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240126/c28a67c6/attachment-0001.htm>
More information about the PROJ mailing list
