[PROJ] Make push and pop FIFO?
Lesparre, Jochem Jochem.Lesparre at kadaster.nl
Mon Jan 29 08:15:14 PST 2024
> Adding a variable name could made be optional? In that case +push +v_3 and +pop +v_3 would still work the old way, but one could also use +push +v_3 +name=ellipsoidalheight and +pop +v_3 +name=ellipsoidalheight.
Could my suggestion above, provide a workable compromise for the solution of my problem? What is needed to find consensus on this topic, or should I create a feature request without specifying a specific solution?
Regards, Jochem
Disclaimer:
De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
[https://www.kadaster.nl/algemene-leveringsvoorwaarden].
Disclaimer:
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
Our general terms and conditions of delivery apply to all our products and services
[https://www.kadaster.com/general-terms-and-conditions].
More information about the PROJ mailing list
