[PROJ] Grid shift files
Javier Jimenez Shaw j1 at jimenezshaw.com
Tue Jan 30 15:18:30 PST 2024
Do you mean a custom location in your hard drive?
Then using PROJ_DATA environment variable is an easy solution. See that is
like a "PATH", separating folders with ":" or ";" depending on your OS, and
it should include also the folder that contains "proj.db".
On Tue, 30 Jan 2024 at 19:15, Mladen Mijatovic via PROJ <
proj at lists.osgeo.org> wrote:
> Dear all,
> My application is using proj 9.3.1. I would like to enable the user to set
> a custom location for his own grid files used for horizontal
> transformations. Is there a way to make proj using a custom location for
> search of these files?
> Best regards,
> Mladen.
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240131/3ad5a8b6/attachment.htm>
More information about the PROJ mailing list
