[PROJ] Grid shift files
Luí­s Moreira de Sousa luis.de.sousa at protonmail.ch
Tue Jan 30 22:35:22 PST 2024
Yes it is. Something like:
PROJ_DATA=/path/to/custom.file;/path/to/proj.db
Regards.
Luís Moreira de Sousa
Sent from Proton Mail mobile
-------- Original Message --------
On 31 Jan 2024, 01:36, Mladen Mijatovic via PROJ wrote:
> Yes, I am thinking about the location on the hard drive, on a local machine where the app is running.
> Is it mandatory to place db file there too? I would like to keep them separtely, not to allow user to mess with the db and ini files.
> On Wed, Jan 31, 2024, 00:18 Javier Jimenez Shaw <j1 at jimenezshaw.com> wrote:
>> Do you mean a custom location in your hard drive?
>> Then using PROJ_DATA environment variable is an easy solution. See that is like a "PATH", separating folders with ":" or ";" depending on your OS, and it should include also the folder that contains "proj.db".
>> On Tue, 30 Jan 2024 at 19:15, Mladen Mijatovic via PROJ <proj at lists.osgeo.org> wrote:
>>> Dear all,
>>> My application is using proj 9.3.1. I would like to enable the user to set a custom location for his own grid files used for horizontal transformations. Is there a way to make proj using a custom location for search of these files?
>>> Best regards,
>>> Mladen.
>>> PROJ mailing list
>>> PROJ at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240131/18a960b7/attachment.htm>
More information about the PROJ mailing list
