[PROJ] PROJ 9.4.0 & PROJ-data 1.17
Javier Jimenez Shaw j1 at jimenezshaw.com
Fri Mar 1 12:29:21 PST 2024
Thank you Kristian!
https://crs-explorer.proj.org/ and https://spatialreference.org/ were also
updated to PROJ 9.4.0
Related to that, there is a trick to inspect the changes in EPSG between
PROJ releases: Check the changes in the file "crslist.json"
In this case in this commit: (load the diff of crslist.json. It is quite
large)
https://github.com/OSGeo/PROJ-CRS-Explorer/commit/99f808ad37c752b25b4d2d5bda9b3d472d578dfc
(Having those tags of crslist.json in GitHub, the webpage allows you to go
back up to PROJ 8.2.1 with a combo-box)
Yes, the diff can be large, specially if they change an area of use that
affects many CRSs. But I find useful to see the added CRSs, or some other
changes.
This time I found a few new German systems that I was not expecting (but I
was missing ;)
Notice that this is only about CRS defintions, not about transformations.
Cheers,
Javier.
PS. PROJ-data 1.17 also adds the Portuguese geoid model GeodPT08
On Fri, 1 Mar 2024 at 18:21, Kristian Evers via PROJ <proj at lists.osgeo.org>
wrote:
> I'm happy to announce the release of PROJ 9.4.0 and PROJ-data 1.17!
> The PROJ release includes a number of updates to the both functionality and
> the database contents, as well as a few bug fixes. See the release notes
> below.
> The PROJ-data release includes the following updates:
> * New revisions of chartdatum Norway v2023b
> * Added fr_ign_RAC23.tif grid for France-Corsica NGF-IGN 1978 to RGF93-2b
> * New DVR90 grids added to reflect recent EPSG-changes that now supports
> all realizations of the Danish height system
> * Added Czech geoid model CR-2005
> Download the archives here:
> https://download.osgeo.org/proj/proj-9.4.0.tar.gz
> https://download.osgeo.org/proj/proj-9.4.0.zip
> https://download.osgeo.org/proj/proj-data-1.17.tar.gz
> https://download.osgeo.org/proj/proj-data-1.17.zip
> /Kristian
> 9.4.0 Release Notes
> Updates
> o Add support for transformations involving coordinate epoch changes
>   (PointMotionOperation), specifically for Canadian NAD83(CSRS)(#3884)
> o SSL_OPTIONS: set SSL options on Curl library (#3936)
> o Add support for unity builds (#3962)
> o Added ability to install *.tif if present in data (#3970)
> o createOperationsCompoundToGeog(): tune selection logic
>   when --grid-check known_available is specified (#3990)
> o Increase CMake minimum version from 3.9 to 3.16 (#3997)
> o CMake: use FetchContent to get googletest-1.12.1 (#4006)
> o CMake: Replace custom FindSqlite3 with FindSQLite3 built-in (#4007)
> o tpeqd: use numerically stable formula for computing the central angle
>   from (phi_1, lam_1) to (phi_2, lam_2) (#4009)
> o Move content of proj_experimental.h to proj.h (#4019)
> o Add +proj=mod_krovak projection method for Modified Krovak that
>   applies to S-JTSK/05 in the Czech Republic (#4021)
> o PROJString formatter optimizer: simplify pipelines doing
>   [Modified]Krovak (South West) <--> [Modified]Krovak (East North)
>   by just doing an axis swap (#4034)
> o +proj=gridshift: enhance to support grids referenced in projected CRS,
>   and with easting_offset/northing_offset corrections (#4038)
> o Tune concatenated operation instanciation, reference CR2005 geoid for
>   Czechia and add (disabled by default) records for Czechia S-JTSK/05 based
>   transformations (#4044)
> o Database: update to EPSG v11.004 (#4062)
> Bug fixes
> o Fix missing symbols at link time for Windows target in Visual Studio
> (#3984)
> o Improve error message in axisswap (#3975)
> o Avoid convergence errors in +proj=gridshift when using biquadratic
>    interpolation (#3985)
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240301/a8d12c4a/attachment.htm>
More information about the PROJ mailing list
