[PROJ] Support request for using PROJ in CMake projects
Even Rouault even.rouault at spatialys.com
Wed Mar 6 08:35:23 PST 2024
Jean,
> Thank you very much for your quick reply.
> Yes I’ve installed PROJ using miniconda, as I already had it installed
> on my computer, it was easier.
> But unfortunately, I got the same error message.
> And I am a bit annoyed having to install PROJ, I just want to use some
> features of PROJ in our opensource project.
> I have QGIS installed on my computer, so PROJ is already installed.
> Moreover, we’re using appveyor for our CI, and PROJ does not seem to
> be pre-installed on appveyor windows images :
> https://www.appveyor.com/docs/windows-images-software/
Yes, too specialized to be on generic purposes CI images
> Does it mean we’ll have to install PROJ on appveyor machine for every
> build of the CI ?
yes
> If you have an example of an opensource project using PROJ with CMake
> and CI, I’m interesting to have its reference.
GDAL, QGIS, etc.
Use a package manager as suggested to install PROJ on your CI: vcpkg,
conda, etc.
For example
https://github.com/OSGeo/gdal/blob/master/.github/workflows/cmake_builds.yml#L425
Or potentially use
https://cmake.org/cmake/help/latest/module/ExternalProject.html, but
you'll likely have the same issues with PROJ's dependencies: curl, libtiff
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240306/ec9168e1/attachment.htm>
More information about the PROJ mailing list
