[PROJ] Meridian convergence
Roger Oberholtzer roger.oberholtzer at gmail.com
Mon Mar 25 00:44:46 PDT 2024
I have been using proj_factors() to get the meridian convergence for a
given point. It has been working great. We need this when projecting LiDAR
points that involve multiple rotations. The code is something like this:
       PJ_FACTORS factors;
       PJ_COORD vals;
       vals.lp.lam = DegreesToRadians(point->LONGITUDE);
       vals.lp.phi = DegreesToRadians(point->LATITUDE);
       factors = proj_factors(tinfo->Meridian, vals);
       return(RadiansToDegrees(factors.meridian_convergence));
I have been using it with Sweref99 (EPSG:4326).
I have two questions:
Is proj_factors() the fastest way to get this information? A look at the
code shows that it is calculating other things as well. Is there is a
faster way? When generating point clouds, each contains 10s of millions of
points, and we generated 10s of thousands of these over a summer. Needless
to say, we are always looking for speedups.
Would this method work for all 'standard' projections? By 'standard' I mean
the typical ones used in, say, European countries. Would we need to
consider anything when extending this to something other than EPSG:4326?
Roger Oberholtzer
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240325/775dd965/attachment.htm>
More information about the PROJ mailing list
