[PROJ] Sndyer Map Projections Manual in HTML form
mircea at neacsu.net mircea at neacsu.net
Sat Mar 30 15:46:05 PDT 2024
Hello,
My work of converting Snyder – Map Projection Manual <https://neacsu.net/docs/geodesy/snyder/>  to HTML is almost finished. Probably the most interesting part are the numerical examples <https://neacsu.net/docs/geodesy/snyder/numerics/> , implemented using JavaScript. All formulas can be recalculated, and one can see all the intermediate steps and the result of those calculations.
I would very much like to hear your comments. Given the number of formulas, I’m sure there are many errors that have slipped through, and I will be grateful if you will point those out.
Thank you,
Mircea Neacsu
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20240330/4ed8a718/attachment.htm>
More information about the PROJ mailing list
