[pycsw-devel] CSW 2.0.2 - APISO 1.0 Implementation
Tom Kralidis tomkralidis at hotmail.com
Mon Apr 4 09:16:02 EDT 2011
Thanks Angelos: I've made some small updates to the wiki.
..Tom
> Date: Sun, 3 Apr 2011 01:55:20 +0300
> From: gcpp.kalxas at gmail.com
> To: tomkralidis at hotmail.com
> CC: pycsw-devel at lists.sourceforge.net
> Subject: Re: [pycsw-devel] CSW 2.0.2 - APISO 1.0 Implementation
> Hi Tom,
> I have added some things in the wiki page.
> Also, the iso/inspire xml importer is now completed and commited :)
> You can find some metadata in the /data/iso-inspire/iso-inspire.db file.
> As you suggested in IRC, I kept the new metadata in a separate file.
> Also, I merged the code from trunk with sandbox, to keep sync.
> Angelos
> On 03/30/2011 11:44 PM, Tom Kralidis wrote:
> > Thanks Angelos.  FYI we will start to roll this into trunk in the  next month or so.  I've started a profile dev documentation page at http://sourceforge.net/apps/trac/pycsw/wiki/ProfileSupport to get high level ideas (most of which come from your sandbox).
> > ..Tom
> > Date: Wed, 30 Mar 2011 04:07:08 +0300
> > To: pycsw-devel at lists.sourceforge.net
> >      Hi,
> >      Right now the ISO profile is being developed as a plugin.
> >      It can be enabled by the main configuration file and it also have
> >      its own configuration file to hold specific information.
> >      I am trying to insert few lines of code in the core DC model, and
> >      the profile code will have to implement some specific functions to
> >      plug in to the core (eg Extended Capabilities).
> >      There is only one major chunk of code in the core model, which
> >      involves the get_profile() function. We probably have to move this
> >      code in the future...
> >      Also in the sandbox, there is some initial work for INSPIRE.
> >      Regards,
> >      Angelos
> >      On 03/28/2011 04:41 PM, Tom Kralidis wrote:
> > .ExternalClass .ecxhmmessage P
> > {padding:0px;}
> > .ExternalClass body.ecxhmmessage
> > {font-size:10pt;font-family:Tahoma;}
> >        We want to extend the current model by adding the ISO specifics
> >        via profile.  We should also consider the DC model as "default".
> >        Any profile will have to map back to the core DC model core
> >        queryables.
> >        Once the profile is loaded, then the CSW request processing
> >        continues like any other request.  For each profile found, the
> >        model is extended (probably in CSW init).
> >        ..Tom
> > Angelos Tzotsos
> > Remote Sensing Laboratory
> > National Technical University of Athens
> > http://users.ntua.gr/tzotsos
> > Enable your software for Intel(R) Active Management Technology to meet the
> > growing manageability and security demands of your customers. Businesses
> > are taking advantage of Intel(R) vPro (TM) technology - will your software
> > be a part of the solution? Download the Intel(R) Manageability Checker
> > today! http://p.sf.net/sfu/intel-dev2devmar
> > pycsw-devel mailing list
> > https://lists.sourceforge.net/lists/listinfo/pycsw-devel
> Angelos Tzotsos
More information about the Pycsw-devel mailing list
