[pycsw-devel] About "GetRecords-filter-bbox Request"
Tom Kralidis tomkralidis at hotmail.com
Mon Aug 8 07:38:56 EDT 2011
FYI after some debugging offline, looks like this was a PATH/PYTHONPATH issue.
> From: Nagai.Junichi at imslab.co.jp
  To: pycsw-devel at lists.sourceforge.net
  Date: Mon, 25 Jul 2011 16:00:12 +0900
> Subject: Re: [pycsw-devel] About
> Hi Tom,
> I'm
  Junichi.
> > Looks like the sqlite embedded functions are
  not being declared. In
> > server/server.py.
  Can you turn on logging (loglevel=DEBUG) in default.cfg. Run the same
  > request and inspect the log file (look for string 'Repository loaded: ').
> > What's the value shown after this? sqlite? sqlite3?
> > ..Tom
> I did on logging (loglevel=DEBUG) in
  default.cfg.
> 'Repository loaded: ' is "sqlite".
> The
  following is an excerpt from the log.
  Mon, 25 Jul 2011 15:34:01] [DEBUG] file=C:\Program Files\Apache Software
> Foundation\Apache2.2\cgi-bin\pycsw\server\server.py line=130
  module=server
> function=__init__ Repository loaded: sqlite.
> What should I do?
  Storage Efficiency Calculator
> This modeling tool is based on
  patent-pending intellectual property that
> has been used successfully
  in hundreds of IBM storage optimization engage-
> ments, worldwide.
  Store less, Store more with what you own, Move data to
> the right
  place. Try It Now! http://www.accelacomm.com/jaw/sfnl/114/51427378/
> pycsw-devel mailing
  list
  https://lists.sourceforge.net/lists/listinfo/pycsw-devel
More information about the Pycsw-devel mailing list
