[pycsw-devel] AttributeError: 'module' object has no attribute 'get_config'
Tom Kralidis tomkralidis at hotmail.com
Thu Jul 21 08:31:49 EDT 2011
> From: Nagai.Junichi at imslab.co.jp
> To: pycsw-devel at lists.sourceforge.net
> Date: Thu, 21 Jul 2011 15:59:31 +0900
> Subject: [pycsw-devel] AttributeError: 'module' object has no attribute	'get_config'
> Dear Tom Kralidis,
> I'm Junichi Nagai from Japan.
> (I'm sorry I can't speak English very well.)
> This time, I've been tried to change the database(from SQLite3 to
> postgres8.3).
> I altered the Configuration(default.cfg:[repository]-database).
> I tried to create the necessary tables and values for the repository by
> using
> "./sbin/setup_db.py".
> I got below error.
>  C:\Program Files\Apache Software
> Foundation\Apache2.2\cgi-bin\pycsw>C:\Python27\
> python ./sbin/setup_db.py "postgres://postgres:postgres@localhost/pycsw"
> Traceback (most recent call last):
>   File "./sbin/setup_db.py", line 88, in <module>
>     CFG = config.get_config('default.cfg')
> Could you tell me what's wrong?
> I use below.
>   pycsw:version1.0.0(http://sourceforge.net/projects/pycsw/files/1.0.0/)
>   OS:Windows XP
>   Python:Version 2.7
>   Database:postgres8.3
Thanks for the info.  I've updated configuration parsing in trunk (http://sourceforge.net/apps/trac/pycsw/changeset/306).  Let me know if this works for you.
..Tom
URL: http://lists.osgeo.org/pipermail/pycsw-devel/attachments/20110721/bda7ac1d/attachment.html
More information about the Pycsw-devel mailing list
