[pycsw-devel] About "GetRecords-filter-bbox Request"
Tom Kralidis tomkralidis at hotmail.com
Fri Jul 22 12:21:45 EDT 2011
Looks like the sqlite embedded functions are not being declared.  In server/server.py.
Can you turn on logging (loglevel=DEBUG) in default.cfg.  Run the same request and inspect the log file (look for string 'Repository loaded: ').  What's the value shown after this?  sqlite?  sqlite3?
..Tom
To: pycsw-devel at lists.sourceforge.net
Date: Thu, 21 Jul 2011 11:13:24 +0900
Subject: [pycsw-devel] About "GetRecords-filter-bbox Request"
Dear Tom Kralidis,
I'm Junichi Nagai from Japan.
(I'm sorry I can't speak English very well.)
I have a question about "GetRecords-filter-bbox Request" of pycsw.
I installed pycsw 1.0.0(http://sourceforge.net/projects/pycsw/files/1.0.0/)
to my OS:Windows.
I created the necessary tables and values for the repository by using
"./sbin/setup_db.py".
I imported all *.xml records(pycsw samples) by using
"./sbin/load_records.py".
(1)
I sent "GetRecords-all Request" to my pycsw
server(http://localhost/cgi-bin/pycsw/csw.py) at
"http://localhost/tester/index.html".
I got collect response from my pycsw
(attachment file:GetAll_Request_Response.jpg)
No problem.
(2)
I sent "GetRecords-Element Request" to my pycsw server.
I got collect response.
(attachment file:GetRecords-Element_Request_Response.jpg)
No problem.
(3)
I sent "GetRecords-filter-bbox Request" to my pycsw server.
I couldn't got collect response.
(attachment file:GetRecords-filter-bbox_Request_Response.jpg)
I got below error.
<ows:ExceptionText>Invalid query: (OperationalError) no such function:
query_spatial u"SELECT records.identifier AS records_identifier,
records.typename AS records_typename, records.schema AS records_schema,
records.bbox AS records_bbox, records.xml AS records_xml, records.source AS
records_source, records.insert_date AS records_insert_date \nFROM records
\nWHERE records.typename IN (?) AND query_spatial(bbox,'POLYGON((-5.00
47.00, -5.00 55.00, 20.00 55.00, 20.00 47.00, -5.00 47.00))','bbox','false')
= 'true'" ('csw:Record',)</ows:ExceptionText>
I sent oher "GetRecords-filter-*** Request" to my pycsw server.
I got same error.
Could you tell me what's wrong?
I use below.
  OS:Windows XP
  Python:Version 2.7
  Database:SQLite3
5 Ways to Improve & Secure Unified Communications
Unified Communications promises greater efficiencies for business. UC can
improve internal communications as well as offer faster, more efficient ways
to interact with customers and streamline customer service. Learn more!
http://www.accelacomm.com/jaw/sfnl/114/51426253/
pycsw-devel mailing list
https://lists.sourceforge.net/lists/listinfo/pycsw-devel
More information about the Pycsw-devel mailing list
