[pycsw-devel] CSW 2.0.2 - APISO 1.0 Implementation
Angelos Tzotsos gcpp.kalxas at gmail.com
Wed Mar 23 18:37:03 EDT 2011
As I am trying to find the best strategy to keep the original code of dc
core intact and at the same time to add all the apiso code into separate
files and classes.
At this point, I have added a apiso module that includes a class named
iso. When the Server _init_ fuction is called, a check is made to the
configuration file to test if apiso profile is active. Then, through a
server.get_profile function, a profile sub-object is created under the
server object containing the additional info needed (mappings, model
additions, namespaces etc).
The original plan was to add specific functions in this profile object
for specific requests (getcapabilities, etc).
Then, redirect by adding checks in front of the dc code to point to the
new functions when needed. This way only few lines of code would be
added to the initial code.
At that point I got the idea that perhaps the dc itself should be
reshaped into a profile object, in order to have consistency, and leave
the original code only with the csw server parts.
Now I see that apiso, can respond to core csw requests by mapping to dc
core queryables when asked to.... which means recursiveness:
server-->apiso profile-->server in case of dc.
Also the mapping has to be decided after parsing the request, so this
seems to change things a bit.
Any ideas?
Regards,
Angelos
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Pycsw-devel mailing list
