[pycsw-devel] Links column from ncISO
Tom Kralidis tomkralidis at gmail.com
Wed Aug 27 12:27:04 PDT 2014
Thanks for the info. Can you point us to a sample record so we can try to reproduce / fix? A GitHub issue would be great.
Sent from my iPhone
> On Aug 27, 2014, at 15:22, Dan Ramage <dan at inlet.geol.sc.edu> wrote:
> Now that I have my server sorted out and running properly, I notice the
> links column is not getting populated.
> I've run the ncISO command line against a single THREDDS endpoint for
> testing. I see issue 238 is addressing the issue, however
> I am wondering if that is in the master branch, I cloned the repository
> from there.
> There could be an issue with the ncISO metadata as well, however it looks
> like the fields are there.
> Dan
More information about the pycsw-devel mailing list
